IssaquahHatch
Feb 27, 2022Follower
WBC502 to WBC502 Video Problem
I have two WBC502's with about 100m apart in a straight line. One is on my Xfinity network with 300 mb/s down and 35 mb/s up. At the remote end of the 502's I get two of the three strength bars, feeding a RAX-10 wireless router. I measure 45 mb/s down and 25 mb/s up using the ookla speed test on my iPhone XR. The ookla video test says I can easily run 1440p. However, any video dialogue runs a bit then freezes. Microsoft Teams with a single video feed, or even FaceTime on an iPhone. Thoughts?
1 Reply
Is the speedtest running off the RAX10 or have you tested it directly into the WBC?
Do you have a straight line of sight between the WBC's? They should be able to handle more throughput at that close of range.
