jellebos
Sep 15, 2016Initiate
wc7500 5ghz only 36 channel in use
Hello, My name is Jelle and i'm working in education in the Netherlands. I have a question about the controller wc7500 I have 15 dual-band wifi accesspoints. All the AP on 2.4ghz are spread autom...
- Sep 16, 2016
Hello jellebos,
Welcome to the community!
I suggest looking at the Channel allocation Configuration > Wireless > Basic > Channel Allocation and see if the channels are enabled:
I'd like to know what firmware version is loaded on the controller and if it has been working fine before.
Thanks,
JohnRo
Sep 19, 2016NETGEAR Employee Retired
Hi jellebos,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
