JCC83
Sep 16, 2018Aspirant
WC7500 and WAC720 with Groups for SSID
Have my 2nd site up using the WC7500 and WAC720. I created a groups for each site. a Group-2 and Group-3. Then assigned the first sites AP to group 2 and the next site to group 3. Each group has ...
- Oct 03, 2018
Power cylcing the AP fixed the issues. When I went back to the site was still advertising both SSIDs instead of just the one, and quickly realized that the signal strengths were also very different when at the far end away from the AP. The SSID that should not have been advertised was still strong while the correct one faded in and out. Did not have the proper software to analyze, but my thoughts are the incorrect SSID was using the 2.4 radio while the correct was using the 5. After power cycling the AP the incorrect disappeared and the correct had a strong signal throughout. Looks like the software hung somewhere between when the AP was frist brought up on the initial group while upgrading firmware and its final state of being moved to the new group. One radio started using the correct settings while the other remained on the previous incorrect settings. No configuration issue in play just need a clean reboot once moved to the new group to actually get the desired behavior.
RaghuHR
Sep 17, 2018NETGEAR Expert
Hi JCC83
We need to understand how you have configured. Could you please share the screen shot of Configuration -> WLAN Network page.
Also share your Configuration backup file?
Thanks,
Raghu
JCC83
Sep 18, 2018Aspirant
I will take a look at the backup config later to remove anything I do not need to share. Here is basic idea though. 2 sites, 2 groups, WLANs assigned to different groups, APs in different groups, but both SSIDs are being advertised from both APs.
- JCC83Sep 18, 2018Aspirant
- RaghuHRSep 19, 2018NETGEAR Expert
Thanks JCC83 but that is not enough.
We need screen shots of all the 4 (Group2 and Group3) profiles.
- Configuration->Profile ->Group2 -> Edit
- Configuration-> Profile -> Group3 -> Edit
- Edit page will have all the ssid configuration and we need screen shots of the profile edit page.
If you can share the config back-up file for us to see how you have configured. You can modify passwords if you think it is security issue and share with us.
Thanks,
Raghu
