JohnDonovan's avatar
JohnDonovan
WC7520 'bricking" WNDAP360 - How to recover the AP ?
HI,
   I have an issue with my EoL WC7520  has 'bricked' a WDNAP360 that it tried to update the firmware on. There are a numer of threads on this already but they often state 'and i recovered the WDNAP360 via the console'  - please can somone direct me to a walktrough of how to do that bit!
Thanks in advance.
  • JohnDonovan,
    Welcome to the community! :)
    What is the current firmware version of the WC7520?
    Not sure if this will help.  I found this old thread here on how to recover the WNDAP360.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    JohnDonovan,
    DaneA
    • JohnDonovan's avatar
      JohnDonovan
      Thanks, that is useful. Do I take it that what appears to be a second Ethernet port is the RS232 port?
      The WC7520 is at the latest (last) firmware.
      • DaneA's avatar
        DaneA
        @JohnDonovan,
        The port next to the factory reset hole is the console port.  Make sure that you set the following settings before you access the WNDAP360 via console: 9600 K default baud rate, (8) data bits, no (N) parity bit, and one (1) stop bit.
        As reference, kindly check pages 12-13 of the WNDAP360 Reference Manual here.
        DaneA
ProSupport for Business
