MLO_Dukes
Oct 12, 2017Aspirant
WC7520 not sending Authentication to Radius
We have 3 Wireless controllers WC7520 and more than 30 AP's (all WNDAP360) in our environment. We configure Radius server on a server running Windows Server 2012r2 with NPS. We using WPA2 with AES en...
- Oct 17, 2017
Hi,
As suggested in the section 5 of the KB article. For WC7520 controller RADIUS client must be added for each access point. For the other latest controller WC7600 you can just add the controller. But for your case you have to add all APs as clients in the RADIUS server.
5. In the next screen, specify a RADIUS client.
In the case of WC7520, a RADIUS client must be added for each access point, while in the case of WC7600 a RADIUS client must be added for the controller only. Ensure that the shared secret entered here is the same shared secret that will be entered into the wireless controller (as described later).
JohnC_V
Oct 16, 2017NETGEAR Employee Retired
I suggest you to upgrade the firmware first of the wireless controller then reset it to factory default and reconfigure it from scratch.
LaxmankumarG
Oct 17, 2017NETGEAR Expert
Hi,
- Nov 23, 2018Retired_Member
