timgowen
Aug 25, 2015Follower
WDNAP360 IP Setup
I need to put a Wireless credit card machine on the network, and have a WDNAP360. The network is configured for DHCP so the AP is getting an IP address for the device. What I need to do is assign...
- Aug 25, 2015
Hi timgowen,
As I have understood your concern, you want to set a fixed or static IP address on the WNDAP360 and on the credit card machine, am I right? If ever I'm right, kindly follow these steps:
a. Login to the web-GUI of the WNDAP360. (I believe you know the IP address of the WNDAP360 since you mentioned that its getting an IP address)
b. Go to Configuration > IP > IP Settings.
c. Select Disable on the DHCP Client.
d. On the IP address field, enter the static IP address you want to assign on it but make sure that its within your network range.
e. Enter the appropriate values according to your exisitng network range on the IP Subnet Mask, Default Gateway and Primary/Secondary DNS Server.
f. Click Apply.
As a guide, kindly check pages 21-22 of the reference manual of the WNDAP360 here.
About your credit card machine, you may refer to its user manual on how you could set a static IP address to it.
Welcome to the community. :smileyhappy:
DaneA
Netgear Community Team
DaneA
Aug 25, 2015NETGEAR Employee Retired
Hi timgowen,
f. Click Apply.
DaneA
