danpool
Jun 23, 2016Aspirant
What is the range of each Access Point attatched to the WC7520 - ProSafe 20-AP Wireless Controller ?
Hey, I've looked everywhere, but I can't find the range that the Access Points have.. I need to know how many I would need.. Does the signal for each one cover a 10m radius or a 20m radius fo...
- Jun 23, 2016
Hi danpool,
About spreading out the wireless connection over an area, you will need to do RF planning. Kindly read pages 41 to 50 of the WC7520 reference manual here.
What NETGEAR ProSAFE Access Point model will you use with the WC7520 wireless controller? If ever you have WNDAP360 access points, according to the review I read online, it says that strong signal strength from a distance of 75 feet can be achieved within a laboratory environment. Here is the link about the review on the WNDAP360 access point.
DaneA
NETGEAR Community Team
danpool
Hey,
Thanks for the message. I thought that's what the access points were for? For spreading out the connection over an area, such as a school.
Essentially, all I'm wondering is what I would need to purchase to cover a big multi story office building.
If I knew how much each device could cover in metres then I could work it out.
I must be completely missunderstanding this technology..I thought you just get one controller and then spread out the connection using access points..
Cheers
DaneA
Jun 23, 2016NETGEAR Employee Retired
Hi danpool,
DaneA
- danpoolJun 23, 2016Aspirant
Hey,
Thanks for the info!
Probably the ones you mentioned: ProSafe Dual Band Wireless-N Access Point WNDAP360
