danpool's avatar
danpool
What is the range of each Access Point attatched to the WC7520 - ProSafe 20-AP Wireless Controller ?
Hey,   I've looked everywhere, but I can't find the range that the Access Points have..   I need to know how many I would need.. Does the signal for each one cover a 10m radius or a 20m radius fo...
  • DaneA's avatar
    DaneA
    Jun 23, 2016
    Hi danpool,
    About spreading out the wireless connection over an area, you will need to do RF planning.  Kindly read pages 41 to 50 of the WC7520 reference manual here.
    What NETGEAR ProSAFE Access Point model will you use with the WC7520 wireless controller?  If ever you have WNDAP360 access points, according to the review I read online, it says that strong signal strength from a distance of 75 feet can be achieved within a laboratory environment.  Here is the link about the review on the WNDAP360 access point.
    DaneA
    NETGEAR Community Team
ProSupport for Business
