mystery9
Jul 06, 2023Apprentice
Why no option for 75% power
Why does the WAX620 not have an option for say 75% power, it goes from 50 to 100% in the drop down options
schumaku
Jul 06, 2023Guru - Experienced User
The intention is to offer some kind of logarithmic scale. This is reflected in the device local Web UI as well as in the Netgear Insight design.
"From the Output Power menu for the radio, select 100%(Max), 50%, 25%, 12.5%, or 4%(Min).The default is 100%(Max)."
mystery9
Jul 10, 2023Apprentice
Thanks, Netgear acknowledged the gap and have raised to engineering to add 75%.
