aminthab
Apr 28, 2017Aspirant
Wi-fi to Ethernet adatpter
My Current system has to be connected to four different control panels which has only Ethernet port ( no-wifi). Do Netgear has any options to connect those 4 panels wireless with some Wireless to...
- May 01, 2017
Hi aminthab,
Welcome to the community! :)
Are the control panels that you are referring to are the same as computers?
Here is the network setup that I suggest:
From the network diagram above, the ports connecting the firewall router and the 1st GS110TP will be configured as tagged ports so that it will become a trunk link. The ports connecting the 1st GS110TP to the 1st WAC730 will be configured as tagged ports as well. Tagging the ports is needed in order to identify which VLAN the packet belongs to. The firewall router that you will use should support VLANs . The purpose of having VLANs is to segregate networks. As an example, two VLANs are configured on the firewall router and the 1st GS110TP namely: Private VLAN and Guest VLAN.
Point-to-Point Wireless Bridging should be configured to connect the 1st and 2nd WAC730. The ports connecting the 2nd WAC730 to the 2nd GS110TP will be configured as tagged ports. Also, both the Private VLAN and Guest VLAN should be configured on the 2nd GS110TP.
I recommend the GS110TP smart switch because it supports VLAN and PoE (Power over Ethernet) so that you can power on the WAC730 access point via the ethernet port . To know more about the specifications of the GS110TP, check its data sheet here.
I recommend the WAC730 access point because it supports VLAN wherein you could assign a wireless network for the Private network as well as for the Guest network that are broadcast at the same time. Also, the WAC730 supports wireless bridging. To know more about the specifications of the WAC730, check its data sheet here.
DaneA
NETGEAR Community Team
sktn77a
May 06, 2017Virtuoso
Have you looked at the netgear wnce2001?
