chopperjock
Sep 11, 2024Aspirant
Wifi 6 ax4200 access point
Hi there, just setting up the AC via PoE+ switch. The AC on/off icon flashes orange. I can see that this either means that the firmware is updating or the AC cannot find the DHCP server. aC has had en...
michaelkenward
Sep 13, 2024Guru - Experienced User
What is this "Wifi 6 ax4200 access point"?
It is not a unique Netgear model number. Many devices come with an AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
Look at the label on the device for the Model Number. And, if there is one, include the "V" bit to show the hardware version. If there is no V number, then you have V1.
To find the right section for questions about whatever it is – probably not here – put the model number into the bit where you can "Search the Community".
See above.
Just another user with time on their hands.
