dabacertia
Dec 13, 2017Aspirant
Wifi trunk (before sale question)
Hello,
Is it possible to establish a wifi trunk of this kind (A or B)?
A.
+ AP in client mode receives different SSIDs and tag them on the nic
- Advantage: the AP that "send signal" can send signal to "normal" clients (computers, smartphones, printer...) and the APs in client mode.
- Advantage: no need to have a dedicated wifi bridge infrastructure
- Need: a specific client mode
B.
+ AP in client mode receive one SSID dedicated to trunk and the "sender AP" sends several SSIDs to normal clients and on SSID dedicated to the wifi trunk
- Need: a specific client mode + a specific "wifi trunk" on "sender" side
Thanks for your ideas/informations/solutions
Hi dabacertia,
Welcome to our community!
It is easier to use the first option that you have. You just need to set the port on trunk where the AP is connected so that it can also broadcast the other VLANs. It will still be depending on the AP you are going to use if it supports VLAN.
- dabacertiaAspirant
- JohnC_VNETGEAR Employee Retired
Hi dabacertia,
Hello John,
Thanks for your answer, I will give it a try. I don't know why I thought it needed special feature to transport a trunk through an wireless network/SSID. It is so simple I did not tried it.
Have a nice day
