Decanigher's avatar
Decanigher
Wifi6 Access point with POE
For home work with professional level of service, I am looking for a POE Switch and 2 access point which I could use in France. I saw some solution with Insight. Do I have to use it even after 1 year free licence ?
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Decanigher,
    What access points do you need for your homework? Do you need a mesh network? Or just plain standalone access points will do? I suggest checking the WAX610 and you may use any of the switches here as long as they support 802.3at/af.
    John
    NETGEAR Community Team
  • You don't have to use and renew the insight license at all or after 1 year. It does make configuring and managing the equipment easier, however, the gear can be used without insight.
ProSupport for Business
