Anonamemouse
Oct 01, 2018Tutor
Wired PC locked out of local network
I recently bought a WAC510 which is set up as an access point. Everything worked fine until I decided that using the Insight app on my iPad might be handy. Somewhere in the registration process it as...
- Oct 01, 2018
With this set-up there is absolutely nothing the Insight Management can make to stop the Gigabit Ethernet/GS105Ev2 connected PC accessing the very same switched network and the TV, the Syno NAS, ....
One thing which is probably lost in the description is a connection from the GS105Ev2 switch to your ISP router LAN port - can you confirm?
Double check there is nothing configured on the other network port (LAN) on the WAC510 - unless i'm wrong that port can't be used in AP mode.Ref. the Insight App data entered:
1. The name "HomeNetwork" is for the Insight platform only, so you can identify and manage that network (Insight does allow the configuration of multiple Networks [or Sites as the Insight Web portal does name the same].
2. The password is the standard password deployed to all Insight manageable devices. With your WAC510 being the only Insight manageable device, this password is deployed only to the WAC510.
Not a single problem visible which might be related to the Insight App - there must be another problem...
schumaku
Oct 01, 2018Guru - Experienced User
- AnonamemouseOct 03, 2018Tutor
Somehow the issue is resolved.
I have reset the switch, the WAC510 and the modem all to factory settings, provided them all with a new password, deleted the network shares from my pc (again), reconnected the shares, and now it suddenly works. I have no clue what the issue was in the end, but I am happy I can get to my files again.
I have removed the app from my iPad.
schumaku, thank you very much for the help!
