Murrayfield
Apr 25, 2023Tutor
Wireless Controller 7500 upgrade to 6.5.5.18 from 6.0.1.0
Hi, Apologies if this has been raised elsewhere but I couldnt find a relevant issue identical to mine. I am remote from the office where my WC7500 exists. I remoted on to a PC on the appropriat...
- Apr 27, 2023
Hi
Thanks for that, it worked in Firefox, I will just have to remember for future reference
Cheers
Ian
schumaku
Apr 26, 2023Guru - Experienced User
Edge in IE mode should work. There is a setting in FireFox to allow TLS 1.0 connections.
- MurrayfieldApr 27, 2023Tutor
Hi
Cheers
Ian
