Dmitriy's avatar
Dmitriy
Wireless controller for WG302
Does anybody know if it is possible to find a wireless network controller that will support WG302 access points? I have a dozen of those and would like to manage and monitor them from some managemen...
  • JohnRo's avatar
    Jun 29, 2016
    Hello Dmitriy,
    Welcome to the community!
    I have checked all of our Wireless Controllers and Wireless Management system(s) but did not find one that will support the WG302 access point. However, upon looking further, I have found that the WG302v2 has an MIB file that you can use for management with SNMP. I believe that is your best bet in managing them as a group. I have also listed all of the AP's that are currently supported by our wireless controller's, see the list below:
    • WNDAP360
    • WNDAP350
    • WNAP320
    • WNAP210
    • WAC730
    • WAC720
    • WNDAP660
    • WNDAP620
    • WN370
    • WND930
    • WNDAP380R
    • WG103 (For WMS5316 only)
    I hope this answers your question.
    Thanks,
ProSupport for Business
