Alexandro
Feb 10, 2019Aspirant
wnap 320 - firmware recovery
Good day Need help restoring firmware. After turning on the wireless point, it hangs. connected the wireless point through the COM port and saw an error (Kernel panic - not syncing: VFS: Unable to...
Alexandro
Hi RaghuHR
controller WC7520 version 2.5.0.47
I started to configure it for the first time; for the first time we set up the controller and the wireless
and the only wireless failed
the rest of the wireless work is fine
I downloaded the firmware from the official site, pulled out the file with the firmware from the archive. It turned out to download this firmware to a wireless one using a COM port. to the address 0x80000000 via tftp protocol, then which command to enter in order for the firmware to be written or set to the address 0x00150000-0x00760000: "rootfs"?
There is no possibility to connect the wireless to the old controller, it burned out and cannot be restored
A new exactly the same controller was purchased, but the problem is that the wireless one does not work, I would like to restore it
Alexandro
Feb 11, 2019Aspirant
Or I do not correctly understand how to restore wireless work. I would be very grateful if you help me
- AlexandroFeb 11, 2019Aspirant
Can you tell me, is there exactly the same wireless, working, with what commands or how can I make a copy of the firmware and upload it to the non-working one?
