Mungon
Oct 28, 2015Aspirant
WNAP210v2 Connection Issues
I have a CG3000v2 cable modem. This is connected via an ethernet cable to a 5 port switch in another room. All devices connected to the router Wifi or switch ethernet function perfectly. I have conne...
- Nov 05, 2015
Hello Mungon,
Please try playing around with the channels. Use channels 1,6 and 11 and see if the connection drops or if it will totally go away.
Thanks,
JohnRo
Nov 02, 2015NETGEAR Employee Retired
Hello Mungon,
Welcome to the community!
I understand you are having an issue with the stability of the connections on the AP, let me help you out. I have seen some post way back regarding this and it appears that a DNS routing issue is causing the disconnections. Try manually assigning a public DNS (Primary 8.8.8.8 and Secondary 8.8.4.4). See image below for reference:
In addition to this, I woul also like to know what is the firmware version that is currently used by the AP.
Looking forward to your response.
Thanks,
Mungon
Nov 02, 2015Aspirant
The WNAP210 Firmware is 2.1.6. I'll change the DNS settings on the WAP - I cannot change the DNS settings on the cable router as these are set by my internet provider (Optus). This will mean they are not the same but I assume this will be OK?
- JohnRoNov 03, 2015NETGEAR Employee Retired
Hi Mungon,
There is no need to change the DNS on the router, just the DNS on the WAP will do. It should be okay even if they are not the same.
Thanks,
- MungonNov 03, 2015Aspirant
That seems to have improved the stability, but I have not had a chance to test it much. I will see how it goes over the next few days. Thanks for your help.
Hello Mungon,
Hopefully it will continue to work properly, keep me posted!
Thanks,
