Mungon
Oct 28, 2015Aspirant
WNAP210v2 Connection Issues
I have a CG3000v2 cable modem. This is connected via an ethernet cable to a 5 port switch in another room. All devices connected to the router Wifi or switch ethernet function perfectly. I have conne...
- Nov 05, 2015
Hello Mungon,
Please try playing around with the channels. Use channels 1,6 and 11 and see if the connection drops or if it will totally go away.
Thanks,
Mungon
Nov 02, 2015Aspirant
The WNAP210 Firmware is 2.1.6. I'll change the DNS settings on the WAP - I cannot change the DNS settings on the cable router as these are set by my internet provider (Optus). This will mean they are not the same but I assume this will be OK?
JohnRo
Nov 03, 2015NETGEAR Employee Retired
Hi Mungon,
There is no need to change the DNS on the router, just the DNS on the WAP will do. It should be okay even if they are not the same.
Thanks,
