Mungon
Oct 28, 2015Aspirant
WNAP210v2 Connection Issues
I have a CG3000v2 cable modem. This is connected via an ethernet cable to a 5 port switch in another room. All devices connected to the router Wifi or switch ethernet function perfectly. I have conne...
- Nov 05, 2015
Hello Mungon,
Please try playing around with the channels. Use channels 1,6 and 11 and see if the connection drops or if it will totally go away.
Thanks,
Mungon
Nov 05, 2015Aspirant
It still drops every now and then but not every 2 seconds so I think it has improved thanks
JohnRo
Nov 05, 2015NETGEAR Employee Retired
Hello Mungon,
Thanks,
