Nisse67
Mar 06, 2016Aspirant
WNAP320 Firmware 3.0.0.7Upgrade Failing, can not access WNAP320 via Internet Explorer
Hello. After upgrad to 3.0.0.7 I can not connect to the AP. I tried both 192.168.0.100 and 192.168.0.236.
- Mar 06, 2016
Hi Nisse87,
Welcome to the community! :)
1. What is the behavior of the LED lights of your WNAP320?
2. Did you perform the firmware upgrade via a wireless connection or wired connection to the WNAP320?
3. Have you tried to reboot your WNAP320?
4. Have you tried to factory reset your WNAP320?
I look forward to your response.
DaneA
NETGEAR Community Team
Nisse67
Hello DaneA!
All LEDs are green and looks normal to me.
Wired connection.
Yes, I hav rebooted the device several times
Yes, I have factory reset also serveral times
I relay do not know what to do!
Thanks for your qiuck response.
Best Regards
Nisse87
DaneA
Mar 06, 2016NETGEAR Employee Retired
Hi Nisse67,
Based from your answers, I recommend you to open an online case with NETGEAR Support here because there is a recovery procedure for NETGEAR Access Point/s and our NETGEAR Support team will be able to assist you with it. However, if the recovery procedure is not applicable nor helpful, then be ready to submit a soft copy of the Proof of Purchase or Sales Invoice of your WNAP320 for warranty verification. A possible replacement will be processed if your WNAP320 is still within the hardware warranty.
DaneA
