zn30
Jun 12, 2016Tutor
WNDAP Firmware - Freezing issues
Hi We have over 50 WNDAP360 accesspoints. They are on firmware version 3.5.5.0 We still have freezing issues, everything seems to be OK on the front leds, but the acesspoint won't connect/answer to...
- Jun 19, 2016
Hi zn30,
I suggest you to post the idea about implementing a restart feature on the WNDAP360 on the Idea Exchange for Business board here. Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to be added to the product's future functionality.
DaneA
NETGEAR Community Team
zn30
Jun 16, 2016Tutor
DaneA
we have allready had several cases about this issue. The answer is "reset to factory default" and it will work for a time....or.... "you can return the old one and we send you a new one"(takes 2 months for a case, we don't have this time anymore)
So therefore I ask you or I don't know who to ask if "You(Netgear) can implement a restart feature.
DaneA
Jun 19, 2016NETGEAR Employee Retired
Hi zn30,
DaneA
- Jan 17, 2024Retired_Member
