Juve's avatar
Juve
WNDAP360 upgrade issue
Hallo everybody ! it is a first time i write here :)  i try to upgrade an access point WNDAP360 to V3.5.20.0_firmware . the problem is: when I logged on GUI i can't  find the maintenance tab to c...
  • Juve's avatar
    Feb 10, 2017
    Hallo JohnRo !
    thank you for your reply !
    i tried all Browsers and nothing changed.
    Hallo Raghu !
    NO , the Setting aren't cloud settings .
    I tried to fix the problem over VPN.
    Today i went to the Company and disconnected the POE cable and every thing went well :)
    LG Juve
ProSupport for Business
