Juve
Feb 08, 2017Aspirant
WNDAP360 upgrade issue
Hallo everybody ! it is a first time i write here :) i try to upgrade an access point WNDAP360 to V3.5.20.0_firmware . the problem is: when I logged on GUI i can't find the maintenance tab to c...
- Feb 10, 2017
Hallo JohnRo !
thank you for your reply !
i tried all Browsers and nothing changed.
Hallo Raghu !
NO , the Setting aren't cloud settings .I tried to fix the problem over VPN.
Today i went to the Company and disconnected the POE cable and every thing went well :)
LG Juve
Juve
Feb 10, 2017Aspirant
Hallo JohnRo !
Hallo Raghu !
LG Juve
- JohnRoFeb 13, 2017NETGEAR Employee Retired
Hi Juve,
That was weird, so after you removed the POE cable and used a regular cable the web-UI corrected itself?
Thanks,
- JohnRoFeb 16, 2017NETGEAR Employee Retired
Hi Juve,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
