Juve
Feb 08, 2017Aspirant
WNDAP360 upgrade issue
Hallo everybody ! it is a first time i write here :) i try to upgrade an access point WNDAP360 to V3.5.20.0_firmware . the problem is: when I logged on GUI i can't find the maintenance tab to c...
- Feb 10, 2017
Hallo JohnRo !
thank you for your reply !
i tried all Browsers and nothing changed.
Hallo Raghu !
NO , the Setting aren't cloud settings .I tried to fix the problem over VPN.
Today i went to the Company and disconnected the POE cable and every thing went well :)
LG Juve
Juve
Feb 10, 2017Aspirant
Hallo JohnRo !
Hallo Raghu !
LG Juve
JohnRo
Feb 13, 2017NETGEAR Employee Retired
Hi Juve,
That was weird, so after you removed the POE cable and used a regular cable the web-UI corrected itself?
Thanks,
