spuch
Apr 03, 2018Guide
WNDAP660 Radius information are buggy in FW 3.7.9.0
Hello together, I already posted a similar message in the German community without any solution, so I will try it here in the wider range of the English community again. I'm using radius auth...
RaghuHR
Apr 05, 2018NETGEAR Expert
- RaghuHRApr 23, 2018NETGEAR Expert
Hi spuch
We have a beta firmware for this case. Please reach support team to get the firmware.
Thanks,
Raghu
- spuchMay 04, 2018Guide
The provided beta firmware fixes the problem with the same NAS-Identifier for all access points. Now the mac address is given, which should be fine. I've tested that on three devices. Thanks for fixing that issue!
Of couse it would be nice, if the Connect-Info could also be set to some value which ist not misleading (e.g. "CONNECT 0Mbps 802.11b" if having a 300Mbps connection at 802.11ng) but for sure this is more a cosmetic aspect
Kind regards
SPuch
