MFriedri's avatar
MFriedri
Follower
Apr 29, 2021
Routing IPs to Vlan Splitting
Hi,
i need a solution for my problem.
I am running two networks on one cable (There are 1 PC and one IP Camera which are both in my celler, both run on a switch (not managed)which then transmitts the signal over one fiber optics cable to my Switch in my office). On the Switch in my Office (Netgear716TV2) i want to take this connection and split it into 2 diffrent VLans one for each IP range. I am a total beginner in this field and need help/starting points to fix this issue.
Best Regard,
M.
  • Dear Customer,
    You have contacted the German-speaking NETGEAR Community.
    We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
    Kind Regards,
    DamianM
    NETGEAR Community
1 Reply
  • DamianM's avatar
    DamianM
    NETGEAR Moderator
    Dear Customer,
    Kind Regards,
    DamianM
    NETGEAR Community
Machen Sie mit!
ProSupport for Business
Mehr erfahren
