meganie
Jun 24, 2022Follower
GS308EPP Link Aggregation
Ich nutze einen GS308EPP, der zwar link aggregation untersützt aber leider nicht nach IEEE 802.3ad sondern nur static link aggregation.
Welches Protokol wird für static link aggregation von Netgear verwendet? Ich würde den Switch gerne in Verbindung mit einer OPNsense Firewall verwenden ich weiß aber leider nicht welches Protokol ich beim Erstellen des LAGG Interfaces auswählen muss.
Zur Auswahl stehen:
failover | Sends and receives traffic only through the master port. If the master port becomes unavailable, the next active port is used. The first interface added is the master port; any interfaces added after that are used as failover devices. |
fec | Supports Cisco EtherChannel. This is a static setup and does not negotiate aggregation with the peer or exchange frames to monitor the link. |
lacp | Supports the IEEE 802.3ad Link Aggregation Control Protocol (LACP) and the Marker Protocol. LACP will negotiate a set of aggregable links with the peer in to one or more Link Aggregated Groups. Each LAG is composed of ports of the same speed, set to full-duplex operation. The traffic will be balanced across the ports in the LAG with the greatest total speed, in most cases there will only be one LAG which contains all ports. In the event of changes in physical connectivity, Link Aggregation will quickly converge to a new configuration. |
loadbalance | Balances outgoing traffic across the active ports based on hashed protocol header information and accepts incoming traffic from any active port. This is a static setup and does not negotiate aggregation with the peer or exchange frames to monitor the link. The hash includes the Ethernet source and destination address, and, if available, the VLAN tag, and the IP source and destination address. |
roundrobin | Distributes outgoing traffic using a round-robin scheduler through all active ports and accepts incoming traffic from any active port. |
none | This protocol is intended to do nothing: It disables any traffic without disabling the lagg interface itself. |
Quelle: https://docs.opnsense.org/manual/other-interfaces.html#lagg
Hi meganie,
willkommen in der NETGEAR Community. Gerne sind wir dir bei deiner Anfrage behilflich.
Die Einrichtung sollte über das zweite Protokoll, fec, durchführbar sein.
Lass uns bitte wissen, ob du hiernach weitere Unterstützung benötigst oder Fragen haben solltest. Wir helfen dir gerne weiter.
Sollte dein Anliegen beantwortet sein und du die Interaktion im Forum als hilfreich empfunden haben, möchten wir dich bitten in Erwägung zu ziehen, den Beitrag gegebenenfalls als akzeptierte Lösung zu markieren. Dies kann anderen Benutzern dabei helfen, die Antwort zu ähnlichen Fragen schneller zu finden. Falls Du weitere Unterstützung benötigst, stehen wir dir unter diesem Beitrag selbstverständlich weiterhin gerne zur Verfügung.Mit freundlichen Grüßen
TilmanS
NETGEAR Team
1 Reply
- TilmanSAdministrator
Hi meganie,
TilmanS
NETGEAR Team
Machen Sie mit!
ProSupport for Business
