Mick14's avatar
Mick14
Follower
Oct 19, 2018
GS716T Hardware Version
Hi all,
does anybody know how to detect the hardware version of a GS716T-Switch? v1, v2, v3?
I tried to retrieve it from the device's memory but draw a blank there. Only the model number appears, the version number does not. I am about to buy a switch second hand and therefore need to know. Thanks a lot in advcance!
Cheers,
Mick
1 Reply
  • Slas's avatar
    Slas
    NETGEAR Employee Retired
    Hallo Mick14,
    Normalerweise gibt es einen Aufkleber mit der Switch Version.
    Du könntest dich auch an den Support wenden und die Seriennummer überprüfen lassen.
    Grüße
    Slas
    NETGEAR Community Team
Machen Sie mit!
ProSupport for Business
Mehr erfahren
