tibatong
Mar 03, 2019Aspirant
Firmware 2.3.0.28
Mein Orbi hat wie immer gemeldet, dass es keine neue Firmware gibt, aber auf den amerikanischen Netgear-Seiten findet sich dann doch eine neue Firmware mit der Versionsnummer 2.3.0.28. Hat die schon einmal jemand ausprobiert? Ist ja immer ein wenig heikel mit den Firmwareupdates bei den Orbis.
- tibatongAspirant
Hier mal die Liste der Änderungen/Bug-Fixes:
New Features and Enhancements:
- Adds customer firmware pull.
- Expands the IP reservation function from 64 clients to 253 devices.
- Adds weak admin password checking
Bug Fixes:
- Includes bug fixes for stability when using Ethernet backhaul in large deployments:
- Wireless backhaul might not change to Ethernet backhaul when an Ethernet cable is connected.
- Reduces the time to stabilize topology with Ethernet backhaul
- Reduces the Ethernet backhaul loop that might cause kernel panic
- Includes bug fixes for stability and performance:
- Fixes the LAN/WAN bidirectional throughput on the DHCP mode drop issue.
- Fixes the downstream drop issue when port forwarding is enabled.
- Fixes the issue where some online games periodicity lag.
- Fixes the issue where the PPPOE connection unstable
- Fixes the issue where the client’s connection type does not display correctly on the Attached Devices page:
- Wireless client connection will show as wired
- Client occasionally shows as connected to the wrong satellite
- Fixes multiple IPV6 issues
- Fixes an issue related to the SSID containing special characters
- Fixes the issue where the user sometimes can't register their Orbi Voice
- Fixes the email address issue on the Security Email page
- Updates the DDNS No-IP privacy policy
- Fixes the following security issues:
- Roll-out NETGEAR Q4 PSV items
- [MR2.2][Guest Isolation] The guest client can access the GUI via an IPv6 address
- FrankHeNETGEAR Employee Retired
- tibatongAspirant
Ich habe ein RBK40-System, das ich um einen RBS20 erweitert habe. Für beide ist die neue Firmware verfühbar. Bisher betreibe ich die Kombi mit Version 2.2.1.210. Ich frage mich nur, warum die Firmware-Update-Funktion noch nie eine neue Version gefunden hat. Das scheint eine reine Placebo-Funktion zu sein.
- tibatongAspirant
Habe jetzt einmal das Update auf die neue Version 2.3.0.28 gewagt. Auffällig (und positiv) war schon einmal, dass sich Router und die drei Satelliten automatisch gefunden haben und keine übliche Fummelei (Ausschalten/Einschalten etc.) nötig war.Auch ist eine kaskadierende Verbindung zustandegekommen, es hängen also nicht alle Staelliten direkt am Router. Ich bin gespannt wie sich die neue Firmware im Betrieb zeigen wird, aber bisher bin ich positiv überrascht.
