buffi66
May 05, 2016Aspirant
Nero Media Home
Hallo, Weshalb ist die App Nero Media Home funktionslos? Habe die Anwendung installiert, kann diese aber nicht starten (ist nur hell unterlegt) Danke Gruß Buffi
JennC
May 06, 2016NETGEAR Employee Retired
Hello buffi66,
I've tried this too and I don't see what it does, does not launch anything. It is a third party app from a non-NETGEAR developer. Maybe you can ask the developer. Found this: https://community.netgear.com/t5/Current-NETGEAR-and-Partners/we-develop-a-app-Nero-MediaHome-for-ReadyNAS/td-p/1046166
- buffi66May 07, 2016Aspirant
:smileyvery-happy: thx
- JennCMay 07, 2016NETGEAR Employee Retired
Hello buffi66,
You're most welcome.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Machen Sie mit!
ProSupport for Business
