buffi66
May 05, 2016Aspirant
Nero Media Home
Hallo, Weshalb ist die App Nero Media Home funktionslos? Habe die Anwendung installiert, kann diese aber nicht starten (ist nur hell unterlegt) Danke Gruß Buffi
buffi66
May 07, 2016Aspirant
:smileyvery-happy: thx
JennC
May 07, 2016NETGEAR Employee Retired
Hello buffi66,
You're most welcome.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Machen Sie mit!
ProSupport for Business
