GautierS49
Jan 21, 2022Tutor
CLI "unknow command"
Hello, My compagnie has just provided me a NETGEAR GS108T and asked me to programmaticaly disable a specified port. To do that, I need to do it manually first with CLI. I have successfull...
- Jan 21, 2022
Hi GautierS49,
The GS108T does not support CLI commands.
Instead, you'll need to access the admin page of the switch by typing its IP address via web browser and going to Switching > Ports > Port Configuration then check g2 and set its port speed to Disable.
Once done, click Apply to confirm its settings.Please let us know if you encounter any issues.
JeraldM
NETGEAR Community Team
JeraldM
Jan 21, 2022NETGEAR Employee Retired
Hi GautierS49,
JeraldM
- GautierS49Jan 23, 2022Tutor
Thank you very much
