ccl13
Dec 04, 2021Tutor
MS510TXUP compatibility issue with Mikrotik RB5009UG+S+IN via SFP?
I think that my MS510TXUP is not compatible with MikroTik RB5009UG+S+IN when connected via SFP port. The issue is this: When I connect my RB5009UG+S+IN via any SFP connection cable I have to MS510T...
ccl13
Dec 05, 2021Tutor
Also I think the log with same timestamp can be out of order. And apparantly, at the exact timestamp of "2021-12-04T17:53:10.144-8:00Z" there's also a link up and link down event. All three cannot be happening at the same time if that's STP causing connection status change.
schumaku
Dec 05, 2021Guru - Experienced User
OK, makes sense.
The issue reminds me to some issue we've (nah, not Netgear) experienced on an SFP+ based network link on two security appliance/router brands, and I think the customer tried some Mikrotik with an SFP+ garage and a similar set of test switches as yours. One of the discoveries was that the router side flapped the links, and did not allow using short/passive DAC.
However, you have tried industry standard fiber modules and experienced the same.
I would suggest to file a support case with Netgear, convinced their switch engineering would be keen to look into this.
YeZ can you assist to establish a link to the switch engineering?
- ccl13Dec 05, 2021Tutor
Thank you schumaku.
Yes I've even tried Gigabyte SFP adapters and they don't work too. And only between RB5009 and MS510TXUP.
If there's anything else I can help provide, please do let me know.
I've just managed to create the factory reset environment again and did a minimal system test, and this is the logs I got:
<181>1 2021-01-01T00:04:16.040Z 192.168.0.239-1 TRAPMGR-5-PORT_LINK_DOWN rsd_l3_intf.c(120) %% Interface VLAN-MGMT link down <181>1 2021-01-01T00:04:16.030Z 192.168.0.239-1 TRAPMGR-5-PORT_LINK_DOWN ksi_snmp.c(230) %% Interface XGigabitEthernet10 link down <181>1 2021-01-01T00:04:16.960Z 192.168.0.239-1 TRAPMGR-5-PORT_LINK_DOWN ksi_snmp.c(230) %% Interface XGigabitEthernet10 link down <181>1 2021-01-01T00:04:16.960Z 192.168.0.239-1 TRAPMGR-5-PORT_LINK_UP ksi_snmp.c(232) %% Interface XGigabitEthernet10 link up <182>1 2021-01-01T00:04:16.960Z 192.168.0.239-1 LLDP-6-NEIGHBOR_DEL proto_lldp.c(4985) %% Neighbor deleted on port XGigabitEthernet10: Chassis ID 2C:C8:1B:FF:AE:42, Port ID bridge/sfp-sfpplus1 <181>1 2021-01-01T00:04:16.950Z 192.168.0.239-1 TRAPMGR-5-PORT_LINK_UP rsd_l3_intf.c(132) %% Interface VLAN-MGMT link up <181>1 2021-01-01T00:04:16.750Z 192.168.0.239-1 TRAPMGR-5-PORT_LINK_DOWN rsd_l3_intf.c(120) %% Interface VLAN-MGMT link down <182>1 2021-01-01T00:04:15.980Z 192.168.0.239-1 LLDP-6-NEIGHBOR_DISCOVER proto_lldp.c(5188) %% New neighbor on port XGigabitEthernet10: Chassis ID 2C:C8:1B:FF:AE:42, Port ID bridge/sfp-sfpplus1 <181>1 2021-01-01T00:04:15.610Z 0.0.0.0-1 TRAPMGR-5-PORT_LINK_UP ksi_snmp.c(232) %% Interface XGigabitEthernet10 link up <181>1 2021-01-01T00:04:14.600Z 0.0.0.0-1 TRAPMGR-5-PORT_LINK_UP rsd_l3_intf.c(132) %% Interface VLAN-MGMT link up <181>1 2021-01-01T00:04:14.600Z 0.0.0.0-1 TRAPMGR-5-PORT_LINK_DOWN rsd_l3_intf.c(120) %% Interface VLAN-MGMT link down <181>1 2021-01-01T00:04:14.600Z 0.0.0.0-1 TRAPMGR-5-PORT_LINK_UP rsd_l3_intf.c(132) %% Interface VLAN-MGMT link up <181>1 2021-01-01T00:04:14.590Z 0.0.0.0-1 TRAPMGR-5-PORT_LINK_DOWN ksi_snmp.c(230) %% Interface XGigabitEthernet10 link down <181>1 2021-01-01T00:04:14.590Z 0.0.0.0-1 TRAPMGR-5-PORT_LINK_UP ksi_snmp.c(232) %% Interface XGigabitEthernet10 link up
This is from two times I tried to cycle the port on RB5009. It might be hard to see, that the first time (at 2021-01-01T00:04:14.590Z) the switch did not even consider the link is up and directly considered the link to be down. And the second time (at 2021-01-01T00:04:15.610Z) the link was up for a very short moment and again, two link down happened.
Above log is captured with Debug level and not skipping anything, just so it might help with debug. I have the full log available if needed.
Also please instruct on how to open a support case - the MS510TXUP is past the 3 month support period and on the support site it directs me to post here for help.
- schumakuDec 05, 2021Guru - Experienced User
I'm not Netgear - and there is no formal bug report path (AFAIK).
Let's wait for YeZ or a Netgear moderator to chime in, they will require a full diag log (on any kind of cloud service, and share the link by PM - not in the public).
Thanks again! That's super helpful already!
