ccl13
Dec 04, 2021Tutor
MS510TXUP compatibility issue with Mikrotik RB5009UG+S+IN via SFP?
I think that my MS510TXUP is not compatible with MikroTik RB5009UG+S+IN when connected via SFP port. The issue is this: When I connect my RB5009UG+S+IN via any SFP connection cable I have to MS510T...
ccl13
Dec 24, 2021Tutor
Please do let me know what I can help. At this moment, my newest discovery is this:
After MikroTik RB4011 upgraded to 7.1.1, the DAC cable connection is also broken. However it is slightly different - the connection is seen as up by both sides, but both sides are only transmitting packets while 100% of receiving packets are with error.
I am sure this is a compatibility issue more on software level, however this only happens with MS510TXUP. I've tried the same on my other switches, M4200 and GC752X, both working totally fine.
- ccl13Dec 26, 2021Tutor
I've got an update. I can confirm that the issue mentioned in my yesterday's post is fixed after a few reboot on both side - I don't know which reboot fixed it, but I am sure that at least first reboot on both side did not fix the issue. And after reboot, I've tried to reboot both side a few times however I was not able to recreate the issue.
Generally speaking, I think my conclusion is there's some compatibility issue between MikroTik RouterOS 7 and MS510TXUP.
