martinah
Jul 29, 2020Tutor
Applying Insight Pro Subscription bought from distribution
I have 3 Insight Pro Subscription packs - each for 3 years - and yet there seems nowhere in the portal to be able to add the Subscriptions ot the devices - only options to buy the subscriptions onlin...
- Jul 30, 2020
This was a big help and far better than the wasted 2 hours of my time on the phone to Netgear when the call was cut off with no resolve having taken my number 3 times in case of being cut off and no call back. Hey Ho.
Still, only problem was that the process was not totally foolproof and one credit was allocated to the wrong organisation adn I cannot see why. I allocated it to the correct organisation, noted a mistake on one of the other organisations and then the credit appeared to go to the latter Organisation without me moving it so no idea what happened in the process. I was convinced I had correctly allocated it to the initial organisation. Still, not the end of the world as I need the same product for that organisation too so no major headache, just like to know what I did wrong. So all is well in my world for now!
THANKS!
schumaku
Jul 29, 2020Guru - Experienced User
Licenes are not applied to devices in Insight Pro.
You must be logged with an administration role account (not a support/operator one), in the top right User menu head to Profile/Account, then Credit Allocation (second item on the left), there you can assign credits to the Customer level.
