martinah
Jul 29, 2020Tutor
Applying Insight Pro Subscription bought from distribution
I have 3 Insight Pro Subscription packs - each for 3 years - and yet there seems nowhere in the portal to be able to add the Subscriptions ot the devices - only options to buy the subscriptions onlin...
- Jul 30, 2020
This was a big help and far better than the wasted 2 hours of my time on the phone to Netgear when the call was cut off with no resolve having taken my number 3 times in case of being cut off and no call back. Hey Ho.
Still, only problem was that the process was not totally foolproof and one credit was allocated to the wrong organisation adn I cannot see why. I allocated it to the correct organisation, noted a mistake on one of the other organisations and then the credit appeared to go to the latter Organisation without me moving it so no idea what happened in the process. I was convinced I had correctly allocated it to the initial organisation. Still, not the end of the world as I need the same product for that organisation too so no major headache, just like to know what I did wrong. So all is well in my world for now!
THANKS!
schumaku
Jul 29, 2020Guru - Experienced User
Licenes are not applied to devices in Insight Pro.
You must be logged with an administration role account (not a support/operator one), in the top right User menu head to Profile/Account, then Credit Allocation (second item on the left), there you can assign credits to the Customer level.
martinah
Jul 30, 2020Tutor
Hi, I was logged in as admin and I looked at this but could only add credits purchased at that time through the website - It didnt allow me an option to insert a licence for ones bought already.
- schumakuJul 30, 2020Guru - Experienced User
Wait - there are two different kind of licenses: The "consumer" ones we can buy on the site, and the "Pro" ones for the Insight Pro environment which are available via VARs/MSPs/Distributors only. The consumer ones can't be loaded on a Pro customer. YeZ your customer need some help here....
- martinahJul 30, 2020Tutor
Hi, Thank you for your reply. :-) However, I think you are missing the point or have misunderstood me, or I havent been clear enough. These are Pro ones (Part number NPRSNG3P-10000S) that I have purchased through our reseller account with Exertis to go wIth the 510 units that we also purchased from Exertis. I simply want to add them to the units that I am not able to do via the Insight Admin portal login. Exertis are saying to get in touch with NetGear but there are no phone numbers to speak to anyone. THanks
- schumakuJul 30, 2020Guru - Experienced UserOh or I've missed to read the complete thread.
https://kb.netgear.com/000060985/How-do-I-activate-my-Insight-Pro-paper-subscription
Does this help?
