martinah's avatar
Jul 29, 2020
Applying Insight Pro Subscription bought from distribution
I have 3 Insight Pro Subscription packs - each for 3 years - and yet there seems nowhere in the portal to be able to add the Subscriptions ot the devices - only options to buy the subscriptions onlin...
  • martinah's avatar
    martinah
    Jul 30, 2020
    This was a big help and far better than the wasted 2 hours of my time on the phone to Netgear when the call was cut off with no resolve having taken my number 3 times in case of being cut off and no call back. Hey Ho.
    Still, only problem was that the process was not totally foolproof and one credit was allocated to the wrong organisation adn I cannot see why. I allocated it to the correct organisation, noted a mistake on one of the other organisations and then the credit appeared to go to the latter Organisation without me moving it so no idea what happened in the process. I was convinced I had correctly allocated it to the initial organisation. Still, not the end of the world as I need the same product for that organisation too so no major headache, just like to know what I did wrong. So all is well in my world for now!
    THANKS!
ProSupport for Business
