Howkoss
Aug 11, 2020Tutor
Cannot change Wifi settings on Netgear Insight Portal.
Cannot change Wifi settings on Netgear Insight Portal. I have 3 connected WAC505 Access points updated to 9.0.0.21 firmware and am getting "One of the request param is invalid" but don't understand w...
DaneA
Aug 13, 2020NETGEAR Employee Retired
Thank you for your response. It seems that the problem is isolated on one location since on the other location, you were able to select WPA3 just fine. It is possible that not all WAC505 access points are upgraded successfully on the location where you encountered the error message.
I suggest you to kindly double check if all WAC505 access points are upgraded successfully to firmware v9.0.0.21 on that same location where you encountered the error message.
DaneA
NETGEAR Community Team
Howkoss
Aug 13, 2020Tutor
Dana, thank you. All three show the firmware at 9.0.0.21. Do you know if I can reload the firmware? If so, how do I do it?
