martinav
Dec 25, 2017Guide
Cost of Insight Management Management
I have already purchased a new wifi system. I got the GC510P and 5 WAC510 APs. I installed the Insight app on my phone. I have two WAC730 APs on my system today. It saw those two devices, and was...
- Jan 12, 2018
Starting from February 2018 with Insight 4.0:
KB-53256: What Insight Subscription Plans Are Available?
KB-53255: What Currencies Will Insight Subscription Plans be Available in?
JohnC_V
Dec 27, 2017NETGEAR Employee Retired
Hi martinav,
As far as I know that the Insight management app is free of charge. No subscription needed in order for you to add devices to it. The one that needed some subscription is the Business Central Wireless Manager. May you be able to add some screenshots?
schumaku
Dec 30, 2017Guru - Experienced User
Hello JohnC_V
Very easy to find in the App ... when connecting to a "new" network, run a scan, and then select [Create new network] we get this (very vague) information:
...once confirmed...
I understand NTGR has to recover some of the cost and effort - however, the management functionality is that limited (compared to the GC or WAC505/510 Web UI admin capabilities) - I find the very low number of free devices more than questionable.
When it comes to the "Limited Support" units where Insight can be used for discovery and a basic online check only with a link to the resective Web URL - adding htis as a "paid" unit would be very strange.
-Kurt.
- JohnC_VJan 10, 2018NETGEAR Employee Retired
- schumakuJan 12, 2018Guru - Experienced User
KB-53255: What Currencies Will Insight Subscription Plans be Available in?- YeZJan 22, 2018NETGEAR Expert
Yes, there will be a very small cost to use Insight Manager to remotely manage devices above 2. It is true that you can manage unlimited number of APs for freeif you use each AP's web interface, just that you won't get free "remote management" through Insight Manager above 2 devices.
