JEDIV
Feb 18, 2020Apprentice
Flaky WiFi Operations with BR500 and WAC510s
Back in September 2019 I was having WiFi problems in the house (see quoted extract below). I am having the same type problems again, even though I have replace the old Nighthawk Wireless Router with...
- Mar 11, 2020
I want to update the community on what my network problem seems to have been. After sending my router config file and logs for my access points and router to the guys in Bangalore, we talked on the phone for about 1.5 hours. After looking at the logs, they told me one device was flooding the network with requests and they gave me the MAC address. That MAC address was my desktop PC, a Windows 10 box. So I turned it off and most of the network problems went away. WEMO, Sonos, Google Home, Nest devices are now all up and running again. So now I need to figure out what on my Win10 PC is flooding the network. Possibly the update mechanism. Thanks to the Netgear guys.
schumaku
Feb 21, 2020Guru - Experienced User
Direct download from the Web UI should be available if I have it right?
JEDIV
Feb 22, 2020Apprentice
Yeah, I just logged onto to my router using a browser, and it was possible to get the config right there.
- RaghuHRFeb 26, 2020NETGEAR Expert
Hi JEDIV
Thank you for sharing the logs. From the log we could see you have enabled the band steering. Could you please disable band steering and see any improments? Most of your devices IoT and all may not support 5 GHz. Please share your feedback on this.
And
- How frequent he is facing the issue?
- Is it recovering on its own or needs to be recovered manually & How?
-Raghu
- JEDIVFeb 26, 2020Apprentice
I am away from home for about a week, so I will have to turn off band steering when I return. I suppose I could do it remotely, but I am reluctant to do that.
- JEDIVMar 04, 2020Apprentice
RaghuHR,
I turned off Band Steering and I will report on whether this configuration improves my system stability. I am confused why that should make a difference, seems Band Steering supposedly is able to detect which devices are dual-capable and only connect the capable devices to 5GHz. Maybe either the Band Steering doesn't work very well, or some devices are not correctly reporting their functionality?
Also, in answer to your questions:
1. It's hard to say exactly how often it occurs since it is random. But I guess I would say once a week or so.
2. It does seem to correct itself, because no matter what I try I cannot seem to fix things by any action I take, such as reboot of modem, router, or APs. It is quite frustrating.
- JEDIVMar 05, 2020Apprentice
Hi guys, well the initial results of turning off band steering are not too good, but I need to give it a few days to settle down. All but one of the 7-8 WEMO devices went offline and haven't come back, and the Sonos gear was not working either.
WEMO devices: 5 wall toggle switches (one is working); 3 electrical outlet switches (none are working).
WEMO devices are all 2.4GHz
Oh, and Amazon's Echo Dot went down too.
- cifellicMar 05, 2020Aspirant
Don't know if you have tried this. I know that when i turned on the 802.11w PMF, some of my devices suddenly stopped connecting.
Everything returned to normal after i turned it off again.
cifellic wrote:Don't know if you have tried this. I know that when i turned on the 802.11w PMF, some of my devices suddenly stopped connecting.
I checked and I do not have PMF turned on. Thanks for the suggestion.
RaghuHR wrote:Hi JEDIV Another thing you can try is by disabling instant wifi and setting Tx power to full will help or not?
My TX power was set to Auto, and when I went to change it to Full, it actually said Auto (Quarter). So I have said all radios at both frequences to Full.
As for as the setting of Instant Wifi, I haven't been able to figure out how to disable that. Let me look at the link you sent one more time.
RaghuHR wrote:Hi JEDIV Another thing you can try is by disabling instant wifi?
Under Instant Wifi, both the Auto Channel and the Auto Power switches are turned off. But after a few seconds that page times out.
- JEDIVMar 06, 2020Apprentice
RaghuHR wrote:Another strange phenomenon that occurs a lot during these times of flakiness. Many of my desktop applications (and sometimes IOS applications) will give me an error message saying that I have no internet connectivity. And yet both IOS and my Windows 10 desktop are showing that I do have internet connectivity, and other applications work just fine (like the browser for example). FYI, I do have NordVPN, but in this most recent episode I do not have it connected.
For example, when I was trying this AM to restore a WEMO light switch, all the process worked fine, but then it could not connect to my local Wifi, but another indication was that I did not have internet connectivity. I think these things are all related.
- JEDIVMar 07, 2020Apprentice
JEDIV wrote:
RaghuHR wrote:So far, the changes I have made (Disabled band steering, disabled instant wifi, and set TX power to full) have not done anything. If anything it's worse. I cannot get two WEMO switches connected again or a WEMO smart switch. Also, three of my nest cameras are offline (one Outdoor CAM, one NestCam, and one old DropCam Pro). The other nest cameras are still working OK.
But here is a real strange one. My Nest thermostats show as offline on the Nest App and via the web interface, but on the device itself the network connection shows as working just fine.
- JEDIVMar 11, 2020Apprentice
