JEDIV
Feb 18, 2020Apprentice
Flaky WiFi Operations with BR500 and WAC510s
Back in September 2019 I was having WiFi problems in the house (see quoted extract below). I am having the same type problems again, even though I have replace the old Nighthawk Wireless Router with...
- Mar 11, 2020
I want to update the community on what my network problem seems to have been. After sending my router config file and logs for my access points and router to the guys in Bangalore, we talked on the phone for about 1.5 hours. After looking at the logs, they told me one device was flooding the network with requests and they gave me the MAC address. That MAC address was my desktop PC, a Windows 10 box. So I turned it off and most of the network problems went away. WEMO, Sonos, Google Home, Nest devices are now all up and running again. So now I need to figure out what on my Win10 PC is flooding the network. Possibly the update mechanism. Thanks to the Netgear guys.
JEDIV
Mar 05, 2020Apprentice
Hi guys, well the initial results of turning off band steering are not too good, but I need to give it a few days to settle down. All but one of the 7-8 WEMO devices went offline and haven't come back, and the Sonos gear was not working either.
RaghuHR
Mar 05, 2020NETGEAR Expert
Hi JEDIV Could you please share the model detaill of your 7-8 WEMO devices? Do you know these devices supports 5GHz band as well? Another thing you can try is by disabling instant wifi and setting Tx power to full will help or not?
Thanks,
Raghu
- JEDIVMar 05, 2020Apprentice
WEMO devices: 5 wall toggle switches (one is working); 3 electrical outlet switches (none are working).
WEMO devices are all 2.4GHz
RaghuHR wrote:Hi JEDIV Another thing you can try is by disabling instant wifi and setting Tx power to full will help or not?
My TX power was set to Auto, and when I went to change it to Full, it actually said Auto (Quarter). So I have said all radios at both frequences to Full.
As for as the setting of Instant Wifi, I haven't been able to figure out how to disable that. Let me look at the link you sent one more time.
RaghuHR wrote:Hi JEDIV Another thing you can try is by disabling instant wifi?
Under Instant Wifi, both the Auto Channel and the Auto Power switches are turned off. But after a few seconds that page times out.
- JEDIVMar 06, 2020Apprentice
RaghuHR wrote:Another strange phenomenon that occurs a lot during these times of flakiness. Many of my desktop applications (and sometimes IOS applications) will give me an error message saying that I have no internet connectivity. And yet both IOS and my Windows 10 desktop are showing that I do have internet connectivity, and other applications work just fine (like the browser for example). FYI, I do have NordVPN, but in this most recent episode I do not have it connected.
For example, when I was trying this AM to restore a WEMO light switch, all the process worked fine, but then it could not connect to my local Wifi, but another indication was that I did not have internet connectivity. I think these things are all related.
- JEDIVMar 07, 2020Apprentice
JEDIV wrote:
RaghuHR wrote:So far, the changes I have made (Disabled band steering, disabled instant wifi, and set TX power to full) have not done anything. If anything it's worse. I cannot get two WEMO switches connected again or a WEMO smart switch. Also, three of my nest cameras are offline (one Outdoor CAM, one NestCam, and one old DropCam Pro). The other nest cameras are still working OK.
But here is a real strange one. My Nest thermostats show as offline on the Nest App and via the web interface, but on the device itself the network connection shows as working just fine.
- JEDIVMar 11, 2020Apprentice
