WFransL's avatar
WFransL
Tutor
Feb 02, 2022
GS108Tv3 continues to report "device(s) lost communication with the NETGEAR Insight cloud service"
Just informing and hoping that you can solve the issue
My GS108Tv3 switches continue to report "device(s) lost communication with the NETGEAR Insight cloud service" although 'Netgear' reported that the problem 'is solved'.
The firmware is 7.0.8.4
Rebooting connects again (for a week?)
  • No disconnects over 28 days since I installed FW 7.0.9.5 !!!
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    WFransL,
    Welcome to the community! :)
    What Insight subscription do you have?
    Was everything working fine before?
    Are there any changes in the settings that might have triggered the problem?
    DaneA
    NETGEAR Community Team
    • WFransL's avatar
      WFransL
      Tutor
      Insight Premium Subscription
      Earlier FW never gave a problem
      Settings have not changed
      • DaneA's avatar
        DaneA
        WFransL,
        Thank you for your response.
        I checked the status of NETGEAR Insight here and everything seems fine.  It is possible that your concern is an isolated issue.  I suggest you to open a support ticket with NETGEAR Support here at anytime for further investigation.
        DaneA
ProSupport for Business
