Scamby
Mar 23, 2023Tutor
How to escalate support case?
I have a support case dealing with my new GS752TPP switches disconnecting from the Insight Cloud. Once they disconnect, they stay disconnected and I can't ping them, access the GUI, etc. The case h...
Scamby
Mar 24, 2023Tutor
All the switches have been assigned static IPs. Once they are rebooted, they reconnect to the Insight Cloud, I can ping the switch static IP and access the switch IP interface. But I don't want to have to reboot the switches every time they disconnect from the cloud. We have had some instances where a switch would disconnect but then reconnect but not recently.
schumaku
Mar 24, 2023Guru - Experienced User
Static IP configured and still no longer reachable after some time? Hard to see an Insight issue - more a generic connectivity or environment issue on what I'm reading here. Out of the blue, no longer reachable by IPv4? Obviously the Insight connection goes wrong, too.
- ScambyMar 27, 2023Tutor
I would think so as well but they only become inaccessible by IP after becoming disconnected from the cloud. Once I power cycle them, they reconnect to the cloud and I can access them by IP. But once they disconnect again, same thing happens. The devices attached to them show no connectivity issues.
- Apr 15, 2024Retired_Member
