Pristle
Jan 13, 2020Aspirant
Insight Cloud Portal - GC110 - Connected Neighbors
Hi, Re: Netgear Insight GC110 (Firmware 1.0.5.25) Am a at a bit of a loss here. I picked up a pair of these switches for a small site, who are hoping to better manage their internet traffic. I h...
Pristle
Jan 20, 2020Aspirant
Hi,
Thank you for your response, not that it was particularly helpful.
Your comment "None of these fields is intended to be edited for the obvious reason" doesn't really elaborate on the 'obvious reason'.
It would seem my site is not populating properly, with only the Netgear and Ubiquiti devices showing up. Of the 15 other available ports, despite all clients being LLDP enable, only 4 are offering up their MAC addresses. None of the ports have 'Neighbor Name' nor 'Neighbor Description' populated.
Even the one port which I have configured with a 'Neighbor Description' via the mobile app, doesn't propogate to the PC based cloud portal.
A very clunky piece of work to say the least.
Paul
schumaku
Jan 20, 2020Guru - Experienced User
Pristle wrote:Your comment "None of these fields is intended to be edited for the obvious reason" doesn't really elaborate on the 'obvious reason'.
All the information shown under Neigbour Info, including the Neigbour Description (App says just Description) is coming from the connected device by LLDP - and can't be edited. That's why it's obvious.
Pristle wrote:It would seem my site is not populating properly, with only the Netgear and Ubiquiti devices showing up. Of the 15 other available ports, despite all clients being LLDP enable, only 4 are offering up their MAC addresses. None of the ports have 'Neighbor Name' nor 'Neighbor Description' populated.
What are these other clients, what kind of lldpd is in place there?
Please note that a common Windows 10 client - with the Microsoft-LLDP-Driver enabled on the interface - does only provide Chassis ID: [MAC], Chassis ID Subtype: MAC Address, Port ID: [MAC], Port ID Subtype: MAC Address - neither a neighbor name or description.
Pristle wrote:Even the one port which I have configured with a 'Neighbor Description' via the mobile app, doesn't propogate to the PC based cloud portal.
Provide more information - "Neighbor Description" isn't editable or configureable. You might talk of the confusing "Port Description" label for two purposes:
a) the Port Description, an editable string on on the switch port (which deploys nicely to both the App as well as the Web UI for me), and
b) the Port Description, in the Neigbor Information, LLDP based, showing the connected device port information, e.g. "Device Port 5" from the connected device.
- PristleJan 20, 2020Aspirant
Schumaku, you response this time has been a lot more concise. Thank you.
Point to note, I can only set and view 'Port Description' via the mobile app. This does not propogate to the Insight Portal. 'Neighbor Name', 'Neighbor Desc.' and 'Port Desc.' remain blank on the Insight Portal. If I select a port, I see a 'Summary' tab and a 'Settings' tab on the left. Under 'Summary' I see the Overview of the port, however 'Settings' is blank. It's in here that I expected to have the ability to assign things like 'Port Desc.'.
The other clients you queried are Hyper-V Servers, print servers and Windows 10 based PCs. The Hyper-V configuration poses it's own unique set of issues, but I can monitor throughput and traffic pattern with other tools there. As for the Windows 10 machines, not all present their MAC to the switch. But then neither do the print servers.
Interestingly, using the tool LDWin on the client machine, the 'Neighbor Desc.' appears in the app on the client PC.
These issues of non-propogation are why I began this quest for answers in the first place. Why, if these entries do not automatically propogate, for whatever reason, why is there no mechanism to make manual entries somewhere?
Paul
- schumakuJan 20, 2020Guru - Experienced User
Pristle wrote:I can only set and view 'Port Description' via the mobile app.
If I select a port, I see a 'Summary' tab and a 'Settings' tab on the left. Under 'Summary' I see the Overview of the port, however 'Settings' is blank. It's in here that I expected to have the ability to assign things like 'Port Desc.'.Some peek-and-poke in my own and customer environments appears like the Settings are shown on PoE switch models (GC110P, GC510PP), but remains empty on non-PoE switches (GS110, GS728X) - must be a bug in the Web portal. YeZ
Pristle wrote:This does not propogate to the Insight Portal. 'Neighbor Name', 'Neighbor Desc.' and 'Port Desc.' remain blank on the Insight Portal.
This is only LLDP data (inlcuding the LLDP Port Name data) and has no relation to switch port configured Port Name.
There is no propagation issue: The Port Description from the other side can only show up if there is LLCP workable - as it is remote data.
Pristle wrote:The other clients you queried are Hyper-V Servers, .... The Hyper-V configuration poses it's own unique set of issues, but I can monitor throughput and traffic pattern with other tools there.
That's unrelated to LLDP, isn't it?
Pristle wrote:As for the Windows 10 machines, not all present their MAC to the switch.
Hm, the Win 10 systems with the Microsoft-LLDP-Driver in place on each interface stack seem to preset the MAC address information to all Insight managed switches for us. (And hey, I'm not Netgear!).
Pristle wrote:But then neither do the print servers.
What print servers are these? Make, model, firmware, ...?
Pristle wrote:Interestingly, using the tool LDWin on the client machine, the 'Neighbor Desc.' appears in the app on the client PC.
LDWin does make use of both the standardized LLDP _and_ the proprietary CDP - where the later is not supported on the Netgear switches.
Regards
-Kurt- PristleJan 20, 2020Aspirant
That then makes sense.
There is no propagation issue: The Port Description from the other side can only show up if there is LLCP workable - as it is remote data.Perhaps I'm not explaining myself well here. By propogation I mean the name assigned in 'Port Desc.' in the mobile app, which while visible in the mobile app, isn't visible in the Cloud Portal (Port Number>Summary>Neighbor Info). Well in my case that's how things are. I refer to the attached image. The 'Port Desc.' can only be modified and seen in the mobile app.
This doesn't seem correct as I thought this was not reliant on LLDP and you suggested in previous advice: a) the Port Description, an editable string on on the switch port (which deploys nicely to both the App as well as the Web UI for me)
By Web UI, do you mean Cloud Portal or
Correct. I included that purely for painting a picture of the site.
I've learned today that a team of auditors has been on site over the last few week or two. They brought with them and plugged in small 5-port unmanaged switches of their own. These have been plugged into wherever they've thought convenient, unplugged client machine from wall and into their switches.
The email I've sent the client this morning has not been subtle.
2 x TP-Link PS110U, which are due to be retired and then 2 x Ricoh Aficio devices.
NeighborPort Desc.' appears in the app on the client PC.LDWin does make use of both the standardized LLDP _and_ the proprietary CDP - where the later is not supported on the Netgear switches.
I've made a correction. In this case I've set the 'Port Desc.' in the mobile app and it's appeared in LDWin. I implemented this tool in my bid to get my head around LLDP. Something I've never concerned myself with. But like so many 'standards' in our industry, seems it is paid lip service by the entities we'd expect more from.
As you can probably gather, I'm not Netgear either.
What I had been hoping to do, was provide the directors of this client with a pictorial view of who's doing what with their limited bandwidth. As things are, I have to provide a separate legend chart explaining who belongs to which port on which switch.
I'm content to leave this here, unless you could provide any further comment on any other obvious things I might be missing. You've provided some good insight (excuse the pun) thus far.
Thanks,
Paul
