schumaku
Oct 15, 2018Guru - Experienced User
Insight Web Portal - Slow Loading
Getting some of the information loaded in the Insight Web Portal does take a lot of time ... 30 to 60 seconds:
From here...
...Poperties shown about 30 seconds later...
YeZ
Oct 17, 2018NETGEAR Expert
Admitted the fact that the loading of the summary page does take some time the first time, it should improve upon later visits, and we'll also seek optimization on the initial loading.
Thank you.
- schumakuOct 17, 2018Guru - Experienced User
Afraid, the slowness is retained after dozens of loads. I'll send you a video. Would be nice if Netgear would seriously look into this as the problem exists - probably specific to my MyNetgear account with some dozen other device registered - as long as the insight Web portal exists.
I would expect that somebody does actively look into it, after my reports were ignored many times before. I'm happy to set-up a TeamViewer session so Netgear can see how bad things are with this environment.
- MrJoshWOct 22, 2018NETGEAR Employee Retired
Hello,
Does the slow loading happen all the time? When did you start noticing the issue first hand? Is all the screens slow at loading or only the summary screen?
- schumakuOct 22, 2018Guru - Experienced User
Josh,
Mainly Summary, but also the Connected (Wireless) Clients - both take about one minute. Demoed today during the Zoom meeting to the WAC and Insight engineering managers.
-Kurt
