kortina
Mar 29, 2023Aspirant
Is it possible to add a Netgear Nighthawk CAX80 to my Insights Cloud Portal?
I use the insight.netgear.com cloud portal and insights app to manage my CAX630 access points. Is it possible to add my cable modem / router here as well? If so, how can I do this? I'd love to be abl...
Mar 30, 2023Guru - Experienced User
The CAX80 isn't insight compatible.
