MattyiceNG's avatar
MattyiceNG
Network Topology & Security Question
Ok I have a fairly complex topology question/issue.  I have my Orbi Pro 6 SXK80 all set up with the VLANS configured as follows:
Port 1 - LAN 1 - VLAN 1 Admin
Port 2 - LAN 2 - VLAN 2 Employees
Port 3 - LAN 3 - VLAN 3 IOT
Port 4 - LAN 4 - VLAN 4 Guest
All VLANS have client and VLAN isolation.
I don't connect anything into port 1 unless router.
For VLAN 2/Port 2 - I need to setup an Insight switch to have every PC connected to be client isolated.  How would I configure that or would it be easier to just use an unmanaged switch since client isolation is already set in router?
VLAN 3/Port 3 - I need to set up a Nest router to get the smart
devices to work.  What issues/problems does putting a separate smart router on this port cause?
VLAN 4/Port 4 - I HATE the Orbi guest portal.  It's not secured and many devices won't connect.  Ideally I would setup a 2nd isolated Nest router to use for Guest wifi.  Will this work?
Thanks!
  • ErwinL's avatar
    ErwinL
    NETGEAR Moderator
    Hello@MattyiceNG
    And welcome to the NETGEAR Community! 🙂
    For VLAN2/Port2
    I guess what you can do is to access the switch GUI/settings and create VLAN 2 and have all the ports you wish to be under VLAN 2 be the member of VLAN 2 with PVID number 2 and connect it to your Orbri Pro 6 router. If that will not work try setting the port  where the Orbi is connected as Tag port.
    VLAN 3/Port 3
    You can connect and setup an access point to port 3. You do not really need a router to make smart devices to work.
    VLAN 4/Port 4
    You can simply connect and setup an access point for guest wifi access.
    You may choose your desired specific devices for switch or access point so I can point you to the right article for the procedure if I can find one.
    Have a lovely day,
    Erwin
    Netgear Team
    • schumaku's avatar
      schumaku
      ErwinL wrote:
      VLAN 4/Port 4
      Dear ErwinL
      Can the DHCP server and routing et all being fully deactivated to allow plugging a standalone router for serving the VLAN?
      Just curious,
      -Kurt.
      • MattyiceNG's avatar
        MattyiceNG
        Thank you for time and thoughtful answers.  Yes, I believe I can do that.
      MattyiceNG
      1. Thanks for the reply and thoughtful answer!  I'm going to tweek this as best I can.  Many thanks!
      MattyiceNG
      Erwin,
      Thanks for the reply.  It's a catch-22; even though the built in wifi on the Orbi Pro 6 SXK80 than on any Google router, a good number of the smart devices require a Google Nest router to work.  Theoretically there shouldn't be any issues but even Google/Nest has posted some (most) of their smart products can only truly work well with a Google/Nest router.
      I want the Google network/VLAN isolated from everything else completely.  But since it's a router I'm plugging into Port 2, should that be a Trunk or Acess port on the Orbi setup?
      • schumaku's avatar
        schumaku
        Such as which Smart Devices are that far off the industry standards that these requiring a Nest Router please?
        Reads like bad marketing, if not worse. What does practically not work?
        Completely isolated? STP and RSTP and similar protocols does always span the full network, regardless of the VLAN config on top. Last but not least, the Orbi Pro SXRnn is the router for all possible (five if I have it right) networks making up the default gateway, handling all NAT (many2one, port forwarding into [one] network, and DHCP for all these).
ProSupport for Business
