nuggets007
Oct 02, 2026Follower
Insight: "Unable to apply the port configuration … Parsing error (status)"
Hi all, Since recently I can no longer change port settings (port name / VLAN ID) on my Insight-managed switches through Insight. Every attempt ends with an email like this: The following operation...
schumaku
Oct 02, 2026Guru - Experienced User
Active Insight Subscriptions always include support.
Head to https://my.netgear.com/support/contact.aspx (login inc case you are not...)
Get Support -> Open a Support Case
Select (x) I have a Subscription Service
Select the Service Opions -> Insight
Best way is then to Call Support (Chat is often overloaded).
Provide a -brief- description...
