rmen55's avatar
rmen55
Follower
Jan 24, 2020
readynas 258x8
I would like to connect my readynas to a single pc that is not on a network. can i connect it thru a usb port?
1 Reply
  • schumaku's avatar
    schumaku
    No, you can't
    Consider using an diect network connection, most simple one Ethernet cable, and manually conigure an IP subnet with two different addresses on the PC and the RN interface.
ProSupport for Business
